3TB HDD and HWiNFO question
nmdelrio
I have been using the HWiNFO plugin with Rainmeter for close to 3 years for one thing to monitor mt SSD/HHDs in my system, with no problems. I am perfectly happy with HWiNFO and Rainmeter.
All in all, I have 1SSD and 5 HDDs, all with less than 2TB capacities.
I replaced a 2TB HDD with a 3TB HDD, which is using a GPT GUID partition table.
I noticed that the HDD read-write activity readings are weird. I am transferring files from a 2TB to another 2 TB, but HWiNFO Program's sensors indicate that I am writing to the 3TB instead, but 3TB is actually idle. There is also no read activity sensed on the 2TB I am transferring files from.
I also tried tranferring files to the 3TB, and its read/write activity sensor say zero activity.
I am running Windows 10 Pro x64.
Am I am encountering this problem because of the 2.2TB limit of Windows OS?
Does anyone know about this issue? Any workaround/fix?
Because now my SSD/HDD Rainmeter skin is giving out wrong information.
Thanks in advance for any information you may share.
This looks rather like a mismatch of drive identification.
Please attach the HWiNFO Debug File and Report File of the system and I will check this.
I tried to attach the debug file, but I keep getting a Cloudfare error. I don't have a report file, how do I get one?
Here's a link to Dropbox instead. debug file
Thanks. Can you also please attach a screenshot of the sensors window showing all disk activity sensors ?
Noticeably, I see the 3TB HDD (Drive: ST3000DM008-2DM166 (Z503M75C)) is not responding to read/write activities.
Screenshot of all disk activity sensors. screenshot
I am copying huge amount of files from the 2TB Drive: WDC WD20EARS-00MVWB0 (WD-WMAZ20089342) to the 3TB Drive: ST3000DM008-2DM166 (Z503M75C) but here's a screenshot showing I am writing to the 2TB (whereas I am reading from it) and no either read or write activity on the 3TB.
Screenshot is attached.
Thanks.
Thanks. I think I know now where the problem is. Will try to fix it in the next Beta build.
Please try the new Beta build v5.57-3235 if this problem is fixed and let me know the result.
Thank you very much, Martin. It works like a charm. I can't live without HWiNFO.
Attached is a screenshot of my left top auxiliary monitor where my HWiNFO-rich system monitoring Rainmeter skins are.
Thank you again for HWiNFO.
