Caveman1996
I looked on your forum multiple times and I never found an answer for my problem... I use HWInfo64 (even the HWInfo32 doesn't make any difference) for the custom fan preset. My problem is that when I use it, the secondary fan for my dual GPU setup isn't affected by the preset that I saved. This is only affected when the crossfire is enable. If it disable, I can control the fan flawlessly.
thanks!
(PS. When I enter the value for the first time and then click on "Ok", the change isn't saved. I need to do this multiple time to make the program take it)
thanks!
