ASRock AB350 Gaming ITX/AC Vcore, AUXTIN1, AUXTIN2 readings
nnyymm
The readings for my motherboard AB350 ITX/AC seems to be off, the Vcore has been stuck at 0.5V - 0.6V and the AUXTIN 1 and 2 is reporting 100 degrees plus.  :s
Can you please attach the HWiNFO Debug File with sensor data, or at least expand the sensor name in the sensors list so I can see which one is used there ?
nnyymm
I'm sorry, what do you mean expand the sensor name in the sensors list? I don't see any options to expand Vcore or AUXTIN1 2.
Anyway I've attached the debug file.
Thanks, the Debug File is what I needed most, no need for anything else.
Sensor values were not properly adjusted for your mainboard. AUXTIN1 and AUXTIN2 are invalid values that should be ignored.
This (and other values including Vcore) will be fixed in the next HWiNFO build.
nnyymm
Alright cool. Thanks!  :D
