Me again. This might not be the fault of HWiNFO64 but something deeper at the OS level, so excuse me if that is the case.
I switched from the MSI X399 to an ASrock X399 Taichi in an attempt to get better RAM performance (it does by a wide margin) but HWiNFO64 sensor window has a very noticeable 'repainting' effect if I don't hit the expand button to spread out the sensors across multiple columns enough times so I don't have to scroll to see any hidden sensors. If there is a scroll bar, there is a long time spent where it seems to 'repaint' the window's contents, populating each text field. The effect is still there to a degree with no scroll bar present, but not nearly as bad.
This might be related to the MSI X399 thread I opened up a while back, but also could be related to something deeper not related to HWiNFO64. Just wanted to spitball some idea back and forth in case you had any ideas.
Video of 'repainting' effect. https://i.imgur.com/1sazC0v.gifv
Also noticed 'hidden' sensors would reappear every other rescan.
