zuldan Member Nov 27, 2023 #1 On my P3 850Mhz, HWiNFO is using 5% CPU all the time (eating my FPS on games). What is the best way to reduce the HWiNFO CPU usage?
zuldan Member Nov 27, 2023 #3 I'm only monitoring the CPU temp and the HWiNFO process sits at 5%. Is there anything else I can do?
zuldan Member Nov 27, 2023 #5 Yep. 3x P3 850 Mhz machines running Win98 with different motherboards. All sitting at 5%
Martin HWiNFO Author Staff member Nov 27, 2023 #6 Well, Windows 98 is not a true multitasking system Anyway, I will try to optimize this in the next (Beta) build to reduce the usage in such case..
zuldan Member Nov 27, 2023 #7 Martin said: Well, Windows 98 is not a true multitasking system Anyway, I will try to optimize this in the next (Beta) build to reduce the usage in such case.. Click to expand... Thank you so much. Amazing support!
