DeadSix27
So I have a couple question and possible bug's maybe known ones:
As a first note and information, I own a ASUS Maximus VIII Hero Z710 and a i7 6700k Skylake.
I do run AI Suite 3 and Corsair Link together with HWInfo 64 Bit Beta 2670
#1 In this image:
The 2 Bottom values sometimes work show a Name & correct value and sometimes don't,
there are also cases where the entire "EC" category goes weird and only shows 1 Sensor, e.g only the CPU PLL or any other.
Do you have an idea why, how I could fix this and whether its a bug?
#2 In this image:
Do you know what Temp2-5 is? and whether I should pay attention to those? I am in fact curious what they represent so that I could rename them accordingly.
#3
Sometimes, atleast it seems that way, that HWInfo, Corsair Link and AI Suite 3 are interferring, either all together or HWInfo with Corsair Link, is that known and un-avoid-able? I assumed that's how HWInfo's Corsair Link implementation works, e.g it kind of takes the data from H110i and thus makes Corsair Link unable to access it at the same time. Any info on that?
Thanks for your time and any help/information you can give!
#1 In this image:
#2 In this image:
#3
