Both GPU and CPU package powers combined......
Vimes
Hello
I have a Z390 Master motherboard (9900k at 5Ghz) and a MSI 3070 GPU. They are the main two components of power usage and I have enabled, also via the RTSS display, to show the CPU Package Power and then the GPU power.
That will give me a separate Wattage of power draw in two lines whilst displaying their values. Is it possible to have the combined Wattage usage to display on one line of those two values...?
You can see the CPU and then the GPU Wattage readings at the bottom of the list of those other values in my attached screenshot.
Thanks
Thanks, seemed to work a treat.....
Thanks again.
EDIT: Read and figured out my last query.
