Bsod while trying to run hwinfo64 5.60
owca6666
Hi, i have just reformatted my harddrive and downloaded latest version of Hwinfo64 but it keeps bluescreening every time i launch sensors.
Here is my .dbg file as i am unable to find a program that can read this.
owca6666
The USB controller should not be a problem in your case, so replacing the SATA driver should be sufficient. Did that help ?
owca6666
Unfortunately not, as you can see on screenshot sata controller is default windows one but hwinfo still bsods as soon as i launch sensors :(
Please attach a new DBG file of crash when using the default SATA driver.
owca6666
Heres new dbg file.
Are you sure this new DBG file is really after changing the SATA driver to the default one? Because in that file I can still see the ASMedia SATA driver being used.
owca6666
I think i managed to fix the issue, i disabled pretty much everything in safety tab and now bsod so far, and yeah im pretty sure that dbg file was new.
I think it was the "ATA Statistics Support" option that disabling helped.
But I was still searching for a solution that would allow to use it with that option enabled.
