Cannot Get it to Start Using Scheduler
LugTheJug
I want to get the auto start to work. Ive tried manually seeing if i can just run it in the task scheduler, but i click run and nothing happens. Not minimized. Im on an administrator account. Its windows 11. Yes, highest access enabled. I tried turning off defender. I tried enabling autostart on or off. Ive been able to run other apps through the scheduler, so im not sure why i cant get it with this. I've seen a lot of people with the same issue posting in simular threads. Seems theres a different solution to each. im at a loss. Thanks
Later HWiNFO versions cannot be launched directly from Task Scheduler but need either a "cmd" or launcher that's automatically deployed when you use the Auto Start feature in HWiNFO.
There is a launcher in the file location (see below). I do not understand how this can help me auto start. I tried using the scheduler as the action for the startup, it says running, but nothing. Big picture, I just want autostart to run, and I am troubleshooting.
Thanks for sharing, there was extensive info in the thread, and it was very helpful. I was able to get it function as needed with an older version (7.72), which works perfect for me. Thanks again Martin for your time, hope all is well.
