can't see fan info
nlehrer54
hi
i am running 6.06 3770 on hp all in one,  model 20-c020 with amd e2-7110 apu and r2 graphics.
i can hear the fan, but show no info in hwinfo.
suggestions? :huh:
thanks
Computer:      HP 20-c020
CPU:          AMD E2-7110 APU with AMD Radeon R2 Graphics (Puma / Mullins/Beema, ML-A1)
                 1800 MHz (18.00x100.0) @ 1197 MHz (12.00x99.8)
Motherboard:  HP 8245
BIOS:          F.44, 11/09/2018
Chipset:      AMD KernCZ
Memory:        4096 MBytes @ 798 MHz, 11-11-12-28
                  - 4096 MB PC12800 DDR3 SDRAM - SK Hynix HMT451S6DFR8A-PB
Graphics:      AMD Radeon R2 Series (BASTROP) [Hewlett-Packard]
                   AMD Radeon APU A6-6200 with R3 Graphics, 256 MB DDR3 SDRAM
Drive:        WDC WD10EZEX-60WN4A0, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive:        hp PLDS DVDRW  DU8AESH, DVD+R DL
Sound:        ATI/AMD Kabini - High Definition Audio Controller
Sound:        AMD Hudson-2/3/4 - High Definition Audio Controller
Network:      RealTek Semiconductor RTL8723BE Wireless LAN PCIe Adapter
Network:      RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
OS:            Microsoft Windows 10 Home (x64) Build 10586.1176 (1511/TH2)
That's most probably because that machine feature a proprietary solution to control/monitor fans.
If you attach the HWiNFO Debug File, I can have a look at that. But chances for being able to support fan monitoring there are probably quite low.
