If I want to change the unit type, for example, change the network upload/download rate from KB/s to MB/s or Mbps, how would I do that ? I cant seem to edit the Unit field.
Go into sensor settings (the wheel at bottom of window) - Custom tab.
There you can adjust the Unit name and using Customize values and applying a 0.001 (or 0.0009765625 if using 1024 as KB) Multiply factor to MB/s.
Yes, rename.
For MB/s you need to divide KB/s by 1000 (or 1024). So using a multiplication factor (proportional to division) 1/1000 = 0.001 or 1/1024 = 0.0009765625. Simple math
