Config (settings) files location
ndxl
Sorry if this was posted before but I'm upgrading my SSD and gonna install a fresh copy of windows. I have HWiNFO set up with Rivatuner to show the things I want in the order I want and I'd rather not have to manually go through it all over again. Can someone tell me where the settings are located so I can just copy paste them on the new windows install?
Thank you.
There are 2 types of settings:
- Portable: stored in the HWiNFO64.INI file
- Machine-specific: stored in registry. These can be exported by clicking "Backup User Settings" in main settings window.
Since I always use the "sensor only" option, the settings menu there doesn't have the "backup user settings" button. The reg file is exactly what I needed, thanks.
Btw HWiNFO is an incredible piece of software, thank you for the amazing work :)
