Glenwing
Alternatively, you can hide voltage or current readings from one of the rails and the power reading will drop to only account for whatever's left (i.e. if I hide the 3V and 12V rails so only the 5V rail is showing at 4A 5V, the total PSU power will read only 20W).
I'm guessing since unchecking the "show" button in the layout options for voltage/current also unchecks "monitoring", the power reading is depending on the data coming in from those other sensors
Unfortunately this means (as far as I can tell) there is no way to hide voltage or current from the Sensors window if you are not interested in those, only in the total power. Also, any way to add an efficiency figure? Corsair Link software monitors both input and output power so in theory it should be possible to pull both of those, and calculate efficiency from that.
