CPU voltage offset not shown correctly
spellman.liu
I set the voltage offset to -0.100v in Intel XTU. However, the HWiNFO64 v7.12 shows 0mv. Please check it. Thanks.
Voltage offsets don't update during runtime in HWiNFO to avoid excessive polling. You'll need to restart HWiNFO if you changed them on the fly.
Then please attach the HWiNFO Debug File, I need to check more details why is this wrong.
This is most probably because the voltage offset is set using an advanced mechanism for each Voltage/Frequency (V/F) point.
This is currently not supported by HWiNFO, but I'll try to address this in the next build.
