Custom Units Newbie
juturna01
Quick, and hopefully easy to answer question. For page file usage and Virtual Memory Load, and probably other sensors as I play with it, I really would like to have these displayed in MB and not just some percentage. When I go into the custom settings, I can't change the unit? I can rename it, but thats all it does, change the name. While im here, page file usage says 1.1%. Percent of what? My total Drive size that that page file is located on? How much windows has allocated to pagefile? Hence why id much rather see it in MB haha.
"Virtual Memory Committed" and "Virtual Memory Available" are the values in MB.
"Virtual Memory Load" is the respective ratio of above values in %.
juturna01
Ahhh so if I want to know what my page file is currently is, I basically subtract the allotment of my physical ram from the total virtual memory committed?
No, I don't think that will give you what you're looking for. "Virtual Memory Available" should be the amount of available page file.
