Display iGPU Processor Name
CoffeeKid
I'm using HWiNFO with rainmeter on my laptop. The laptop is using the iGPU and has the GPU tuned off until it needs it.
When I look at the iGPU sensor the name is a repeat of the CPU name. Can it instead show iGPU processor name?
In my case the CPU is "Intel® Core i7-4800MQ" and the iGPU would be "Intel® HD Graphics 4600".
You can rename the label of that reading, though it will still be under the CPU sensor. Not sure if that's something you're looking for. Otherwise iGPU values would need to be placed under a separate sensor of such a name.
