empty memory info
pha
Empty summary window, but this info present in report
[attachment=2711]
Code:
Memory Devices ------------------------------------------------------------
Physical Memory Array -----------------------------------------------------
  Array Location:                         System board
  Array Use:                              System memory
  Error Detecting Method:                 None
  Memory Capacity:                        64 GBytes
  Memory Devices:                         4
Memory Device -------------------------------------------------------------
  Total Width:                            64 bits
  Data Width:                             64 bits
  Device Size:                            8192 MBytes
  Device Form Factor:                     DIMM
  Device Locator:                         ChannelA-DIMM0
  Bank Locator:                           BANK 0
  Device Type:                            DDR4
  Device Type Detail:                     Synchronous
  Memory Speed:                           3466 MHz
  Manufacturer:                           029E
  Serial Number:                          00000000
  Part Number:                            CMK16GX4M2B3200C16
  Asset Tag:                              9876543210
  Total Width:                            0 bits
  Data Width:                             0 bits
  Device Size:                            0 MBytes
  Device Form Factor:                     Unknown
  Device Locator:                         ChannelA-DIMM1
  Bank Locator:                           BANK 1
  Device Type:                            Unknown
  Device Type Detail:
  Manufacturer:                           Unknown
  Serial Number:                          Unknown
  Part Number:                            Unknown
  Asset Tag:                              Unknown
  Data Width:                             64 bits
  Device Locator:                         ChannelB-DIMM0
  Bank Locator:                           BANK 2
  Device Type:                            DDR4
  Manufacturer:                           029E
  Total Width:                            0 bits
  Data Width:                             0 bits
  Device Locator:                         ChannelB-DIMM1
  Bank Locator:                           BANK 3
  Device Type Detail:
  Asset Tag:                              Unknown
Memory Array Mapped Address -----------------------------------------------
  Starting Address:                       00000000
  Ending Address:                         00FFFFFF
  Partition Width:                        2
Memory Device Mapped Address ----------------------------------------------
  Ending Address:                         007FFFFF
  Partition Row Position:                 Unknown
  Interleave Position:                    1
  Interleave Data Depth:                  2
  Starting Address:                       00800000
  Interleave Position:                    2
That looks like something in the system is blocking access to DIMM SPD or entire SMBus.
Are you perhaps running some other system monitoring tools in parallel with HWiNFO ?
Note: Summary won't show memory information from SMBIOS DMI as this is often not accurate.
pha
How it can be detected?
No only HWiNFO at the moment.
Other software shows SPD info and memory modules
[attachment=2712][attachment=2713]
pha
sometimes memory modules is present...
[attachment=2714]
There are 2 dbg files w\o memory and with it.
  • HWiNFO.7z
Is the appearance of memory information totally random, or are you able to determine some pattern how to reproduce the non-appearance ?
pha
regularity:
fresh boot
run cpu-z (close or leave opened - does not matter)
hwinfo able to see memory info
So without running CPU-Z after boot HWiNFO never sees memory modules?
Does AIDA64 always see memory modules and after running it does HWiNFO too?
pha
Without CPU-Z HWiNFO never sees memory modules (99%).
Aida64 - same behavior as HWiNFO.
OK, I think I know where the problem is :) Will try to fix that in the next (Beta) build.
