M madeinlisboa New Member Jan 20, 2021 #1 It would be great if each entry in system tray could have the entry name appended to the rest of the info. I have several disks and I don't recall every one of them by the color.
Martin HWiNFO Author Staff member Jan 20, 2021 #2 You can rename any of those items in the main sensor window.
M madeinlisboa New Member Jan 20, 2021 #3 Martin said: You can rename any of those items in the main sensor window. Click to expand... ??? I know I can. What I asked is for them to be shown in the tooltip. Did you see the picture?
Martin HWiNFO Author Staff member Jan 20, 2021 #4 You can rename the "Drive Failure" item to include the drive name, i.e. to "Drive C Failure". That will be then reflected in the tray tooltip as well.
M madeinlisboa New Member Jan 21, 2021 #5 Martin said: You can rename the "Drive Failure" item to include the drive name, i.e. to "Drive C Failure". That will be then reflected in the tray tooltip as well. Click to expand... Thanks for the tip. Anyway, please accept my suggestion for future updates
