external SSD temperature
Mark1188
I am monitoring an external SSD. The read/write speed numbers change every time, but the temperature updates do not change in detail. On the other hand, if I manually update CrystalDiskInfo finely, the temperature will change and be displayed. I would like to know if there is a measurement timing setting for each sensor. The temperature of the built-in SSD changes at small timing, just like reading and writing.
This is most likely due to a different polling of S.M.A.R.T sensors. Check in Sensor Settings - "Polling Period" -> "Disk S.M.A.R.T. every ... cycles"
