Fan control and which CPU temp to use
aaronac8
I am using the program Fan Control and hwinfo for CPU temps. Which CPU temp sensor is best to use to control my air cooler fans for my CPU?
We don't recommend Fan Control for two reasons:
  1. Running this software (especially the LibreHardwareMonitor component it's using) along with HWiNFO can cause conflicts between both software. There were several reports of issues in the past. This might have been fixed/improved in later releases, but we haven't verified this yet.
  2. LibreHardwareMonitor uses a vulnerable kernel driver (WinRing0) that's already blocked by some antivirus software. Original version of this driver is also on Microsoft's blacklist, although not yet applied to some forks like LHM.
Is there another program that you recommend to control my systems fans? Also, which CPU temperature is the best one to use to control my air cooler fans? Thank you for your reply.
By default, AMD uses the "CPU Tctl/Tdie" sensor for CPU cooler temp control.
Tctl = T_control
This is what the board will use in BIOS to control CPU cooler through CPU_FAN header or CPU_OPT header, if no third party software is installed.
