Is it possible to get fan speed into HWInfo64? I use G-Helper instead of Asus software to control power and oc settings.
Thanks a lot
Gimbler
PS: I <3 HWInfo!
It might be possible if you can provide:
- the HWiNFO Report File
- dump of the DSDT ACPI table using www.hwinfo.com/beta/FirmwareTablesView.exe.zip - run it and right-click on the DSDT table -> Export to Binary File
