Fan speed for Asus Zenbook UX433FA
Daksol
Looks a great product.
Question - where can I find the info on the Fan Speed of my Asus Zenbook UX433FA?
I have exported the report to HTML and searched its source, but cannot see any mention of "Fan".
This machine has BIOS Version: UX433FA.309 15-July-2019
I have another utility which is able to show Fan speed, so I presume the Fan RPM is available for some sensor.
SpeedFan v4.52 from http://www.almico.com/speedfan.php
fyi - The Search on this Forum does not accept a search string like "Fan" or "Fan RPM"
Daksol
Thanks for info. Regret I don't have any knowledge of the hardware at that level. I have looked at the SpeedFan website which has a database of motherboards etc. https://www.almico.com/forummotherboards.php
That project is not open source, but the author clearly has a deep understanding of issues around the control of fan - and explains how this has been approached https://www.almico.com/sfarticle.php?id=5
Though I am not sure if the project is still being maintained - last updates of website in 2020 I think.
Daksol
Hi.
Kudos for taking on this kind of task - though I fear it might be somewhat akin to "boil the oceans" given the diversity of hardware around.
See attached files as per your post.
* Zip file consisting of three files
* The HWINFO report, saved as HTML
* RWEverything file saved from the EC option
* Once with fan stopped
* Once with fan at 855 RPM
Additional Info on fan speed according to "Speedfan" utility
* Speedfan screenshot showing that this utility has an oddity in how it reports the fan speed when fan is not running.
* When the fan is stationary it reports the fan at 4,294,967,296 RPM (which is 2^32).
  • AsusZenbook_UX433FA_HWInfoReport_RWEverythingECReports.zip
Thank you for the data. Unfortunately this model is somehow strange as both EC dumps you attached are empty (all fields are 0's), so I'm sorry but I don't know how to read the fan speed here :(
Daksol
Kk. Possible i ran RWE wrongly?
This was first time I have used RWEverything.
With the RWE app i first installed the 64but version . Then I opened it, and clicked the EC button in the app toolbar. Was that sufficient?
Should I have run RWE as Admin?
(Speedfan runs as admin)
RWE should be definitely run as Admin, I though it's automatically asking for it.
