Found bug trying to run with command line switches
tiker
Just a note, I found a bug trying to run HWinfo32 with command line switches like -txt=whatever - You'll get the prompt attached as image1.jpg.
Click run. You'll see image3.jpg.
Thanks.
(Just as an extra note, the "sensor-only" option which is saved as enabled doesn't show when launching from a command line and shows as not selected in the attached image.)
Thanks, I'll check this.
Anyway, running HWiNFO with command-line parameters is currently not supported. I'm considering enabling this option in the future...
tiker
Ya, I figured as much. I was looking for a command line utility that can dump processor name, core and thread counts to a text file and was hoping I could use HWinfo.
