Gigabyte Z490 Vision D missing ec_temp1 but ec_temp2 showing ok?
Hi all,
I have a Gigabyte Z490 Vision D with a 10900k running F20 bios. I have an open loop watercooling setup with ec_temp1 reading water temp and ec_temp2 reading intake (ambient) temp. The Temperature 2 value (under ITE IT8792E) matches the ec_temp2 correctly and I could have sworn that in the past Temperature 1 matched ec_temp1 but it either never did (and just was close enough to fool me) or something changed.
I installed Gigabyte's SIV software and it correctly shows ec_temp1 but strangely doesn't show ec_temp2 and some of the fans that HWInfo shows. Their SW is junk so ...
Thoughts on how to get this resolved?
Berardino
I will need to see the HWiNFO Debug File to check in detail why it's not showing them.
Thanks, this will be fixed in the next (Beta) build.
Currently what's shown as "System2" should be EC_TEMP1.
I've been away from my computer for a while but can confirm that the latest beta does fix all the temp sensor names. Thanks again!
