Gigabyte Z68XP-UD3 wrong temps
CUS
Hi :)
Just noticed temps in HWiNFO are different to Gigabyte's TouchBIOS software.
In HWiNFO:
Motherboard temp matches System temp in TouchBIOS
CPU temp does not match any temp in TouchBIOS (Could this maybe be case ambient temp)
Temperature 3 matches CPU temp in TouchBIOS
I'd love to know what the extra temp reading is for as this is not shown in TouchBIOS.
Screenshot http://img.photobucket.com/albums/v79/cusman/HWiNFO64.jpg
Hope this helps and thank you so much for this wonderful software :heart: :)
Best Wishes,
CUS.
P.S - Using HWiNFO 64 V3.92-1515
Hmmm, that's a good question :) Are you sure that EasyTune is right and your CPU ext. temperature is really only 16 C (maybe your machine is in Sibiria ;) ) ?
Anyway, I'll make it matching the CPU temperature with EasyTune. As for the unknown temperature, I suppose that only Gigabyte knows to which sensor input it belongs...
CUS
Hey Martin :)
Thank you for such a quick reply.
Am I sure Easytune is right?...not at all lol but I have no way to check unfortunately.
Regarding temps, I've just run Battlefield 3 on ultra settings for roughly 30mins to see the difference.
Looks (to me) like CPU temp in HWiNFO isnt doing anything.
Im hoping sensors in my PC are okay...its a brand new custom build By Aria PC in Manchester UK http://www.aria.co.uk/ so they should be okay.
Here's a screenshot with Battlefield 3 running in the background
http://img.photobucket.com/albums/v79/cusman/HWiNFO64gaming.jpg
Do these temps look more inline with what they should be? (my last PC until lastweek was AMD Athlon 64 3200+ LOL, so *a little* out of touch with running temps :blush:)
Hope the screenshot helps...thanks again :D
P.S...not quite Sibiria, but Manchester is FREEZING today (check weather in screenshot B-r-r-r!)
CUS.
Thanks for the screenshot, that explains it even better. I'll exchange those two temperatures in the next build, so now they will be inline with EasyTune.
You have a beautiful weather there :) Today it was -10 C here during day and two days ago -20 C ;)
