GPU Sensors reporting abnormal numbers (RX 9070 Nitro+)
I have been getting these crazy high numbers for most gpu sensors with HWinfo for a while now. My graphics card is a 9070 Nitro+ from Sapphire. Only my graphic card sensors have this issue, rest of the components give normal numbers. Is this a bug with the software or should I be concerned about my gpu?
Specs if anyone needs them:
  • Ryzen 7 7700
  • Thermalright Royal Knight 120 SE
  • Asus TUF B650M E Wifi
  • Crucial DDR5 Pro OC 6000Mhz 32GB (36 CC)
  • Crucial T700 Pro 2TB
  • Seasonic Focus GX 750W Gold+ ATX 3.0
That's certainly an erratic readout, nothing to worry. Does it maybe happen during sleep/resume or driver update?
Hey Martin, thanks for the quick response and yeah, you are right. This happens after waking the PC from sleep.
Is there any way to fix this? I like to check the max temps of my GPU from time to time so reporting accurate sensor data is important to me.
I will need to see the HWiNFO Debug File capturing this erratic situation. Can you please create such and post here?
You need to run with Debug Mode enabled and attempt a few sleep/resume until the problem occurs. Then close HWiNFO and grab the DBG file.
Also, make sure to use the latest HWiNFO version.
Hey Martin, Here's the [deleted] please let me know once you have downloaded it so I can stop sharing it :)
wow that fast, thank you! When can I expect the update?
one more thing - i think i have auto updates disabled so i wanted to enable it but couldnt find anything related to updates in the settings.
since the topic fits the current AMD GPU right now.... with the driver update 25.6.1 I am missing the GPU power values
Can also confirm the missing 9070 XT sensors when running 25.6.1 are restored with hwi_827_5750 beta.
Yes, all Beta are in portable format only. Just copy the file from portable package to replace the one in installed folder. Or if you have the Pro version, it will do the job automatically.
