High CPU load | RTX 2050 Mobile
xairaven
Hi! I use HWiNFO 64 8.00-5400. I'm stuck with the same problem as in thread "High CPU load". The process takes about 20-25 percent of my CPU. I did the timing profiling trick and found that the GPU sensors need about 1500-2000ms. After this experiment, I hit "Del" on the GPU label, and the CPU load with HWiNFO went back to normal. Is there any fix for this? My laptop - Acer Aspire 5 A515-57G(-56SZ). ID - NX.KMHEU.005
Since those GPU sensor values are provided by GPU drivers, I'd first recommend to update the NVIDIA GPU drivers.
