hwinfo 7.64 -h parameter -> return value not 0
fhj32
hello,
in previous versions the return value from the param call -h was 0.
if i call hwinfo 7.64 from the command line the return value is not 0 (-1073740791)
thanks
yes the log file is generated.
But i check via script the return value, and now with the latest version my script report an error after generation.
thanks
Thanks, I think I found the bug. It shall be fixed in the next (Beta) build.
