HWInfo cause increased heat?
jriker1
More of a curiosity with it running and all the sensors it's monitoring. With an AMD 7950x that will ramp up speeds just hitting a key on the keyboard, does having HWInfo running minimized effect idle temps? If anyone knows.
Minimization should have no significant impact. It's rather some sensors that might take more time to read out. In such case you can enable the "Profiling Time" column and check if there are any taking excessive time to read.
