HWINFO detecting wrong RAM frequency info.. ?!
Bus Clock of 93.9 MHz is the problem but I'm not sure why this is reported as such.
Please attach the HWiNFO Debug File for analysis.
Sorry, but that's still not the Debug File. And besides that it says:
Virtual Machine Warning: Microsoft Hyper-V is active. Some results may not reflect real hardware !
not sure why it is still not debug even though i did everything as per instructions (can be seen in video). and as you can see in video (which i attached), hyper V is already inactive...
will try to figure out on my own. thank you :)
Oh sorry, I missed that.
For the Debug File - after closing HWiNFO64 you also need to grab the HWiNFO64.DBG file located in its installation folder.
I can also see that on the main screen HWiNFO detects presence of Hyper-V so even though the system says the Hyper-V component is not installed, there must be something else in the system keeping it active. Maybe try to enable Hyper-V and then remove it.
problem solved... i disabled hyper v using cmd using "bcdedit /set hypervisorlaunchtype off".. everything fine now..
