Are those fans spinning? Because raw data show all fans off.
Yep. I have big GeminII cooler with 2x 120mm fans. Also 90mm fan for mobo blowing.
If yes, will they show up when you run the ASRock A-Tuning tool?
I don't use any software from ASRock.
But I want to note that if, after starting HWiNFO, I run AIDA64, which shows fan sensors, then fan sensors appear in HWiNFO too.
PS. It is possible that the ASRock implementation of sensors is a bit strange.
There are two connectors on the mobo itself: 4-pin CPU_FAN1, which controls only PWM fans - if I connect a 3-pin fan to it, it just will rotate at maximum speed; and there is 3-pin CPU_FAN2, which controls only 3-pin DC fans.
My CPU cooler has two fans with 3-pin connectors, so I connect them to CPU_FAN2 via a 3-pin fan splitter.
But in any case, AIDA64 can display the speed of all fans, even case fans.
