hwinfo not reading cpu fan speed
Wire11
when lounch axtu (asrock extreme tuning utility) the cpu fan is listed. but if I don't lounch axtu, hwinfo not listen cpu fan speed. in bios fans speeds are listed.
Which exact mainboard model do you have ?
It's possible that the CPU fan is muxed with another one, which is common for some ASRock mainboards.
Wire11
asrock extreme 9 990fx
That model is as I described earlier. Unfortunately the method to access and read the fan is not reliable, doesn't work well and could cause issues, so it's not supported.
As a workaround you can try to attach the fan to another header (CPU1/2, or another one).
Wire11
cpu2 fans has 3 pin and it is reading earlier from hwinfo. cpu1 has 4 pin (pwm) and not is reading from hwinfo.
Wire11
can you fix the program for that motherboard? :p
I have already explained the reason and suggested attaching that fan to a different header.
eswen
 It sounds like this is a known issue, I have a 2013 M18X R2 and my cpu fan is not showing up. The 2 gpu fans are showing up linked.
I tried to upload a report but this site says it doesn't allow those types of attachments. is there a format and or best place to upload the report files?. Is this something you guys are working on by chance?
thanks a bunch for the help!
I have attached a word document with some screen grabs of the reports. nope apparently not that file type either
That seems to be a firmware issue/limitation and in that case I cannot do anything about it.
If you have problems attaching file, try to compress them (zip, etc.).
