HWiNFO not responding - Gets Stuck on Analyzing Memory Configuration
korsa777
My HWiNFO keeps getting stuck on analyzing memory configuration. I tried reinstalling and switching versions. Even getting this debug report generated was difficult as it would stop responding even in debug mode. This report generated after I left it running and came back after many hours.
Thanks for the assistance.
Something else in the system is blocking access to SMBus. Are you running some other system monitoring or RGB control software?
I'm not actively running any RGB control software. I tried rerunning HWiNFO after shutting down MSI Afterburner and Rivatuner, but it immediately got stuck on analyzing memory configuration again.
There must be something else running in the system causing this issue. What else interacting with hardware is running there?
I'm not sure. I tried running HWiNFO today and didn't stop/uninstall anything else and it ran perfectly fine. Attached is the debug report from today.
Well yes, this time it worked well. But previously it couldn't access the DIMM SPD due to being blocked by something else.
