I've had this problem for a while (somewhere in 2021-2022 iirc). HWiNFO would forget my sensor window size (and position) settings at times. When it happens, the sensor window size is shrinked to the size as if there is only 1 column of sensor (but my setup is 2 columns), better illustrated in below images:
This is my normal setup
But when the bug occur, the window size is shrinked as following (roughly the size of 1 sensor column / the left side in my normal config window)
The window position is also reset to locate right in middle of screen (vertically + horizontally, excluding taskbar)
I have tried many things, with workarounds suggested in HWINFO does not retain window setting and ALWAYS forgetting window position threads but to no avail. Here are things that I've tried:
The settings I mentioned only worked for a while (could be snake oil) and then the bug occured again. I think it's time to report and work out to resolve this issue once and for all : P
- Setup window size + position and close using X button
- Toggling options
- Snap Window Edges
- Validate Window Positions
- Use the fresh settings of HWiNFO64:
- Use default (non-customized) layout of sensors
- Use default preferences settings
- Use default font
- Configure in HWiNFO64 in Task Scheduler:
- Set startup delay of 30 seconds
- Change startup trigger from "At log on" to "On workstation unlock"
- Fresh re-install HWiNFO64 (uninstalled using BCUninstaller)
- Fresh re-install Windows (format drive + install)
- I even switched to another laptop but the issue still persists : D
