HWiNFO v6.15-4010 Beta released
HWiNFO v6.15-4010 Beta available.
Changes:
  • Enhanced sensor monitoring on GIGABYTE X299X and TRX40 series.
  • Added monitoring of Noise sensor on some GIGABYTE mainboards.
  • Added reporting of total Average Effective Clock.
  • Added reporting of SATA/NVMe current interface in summary.
  • Added reporting of PBO Scalar value for AMD Matisse.
  • Improved reporting of HDA Codec.
  • Fixed losing of some sensor items on some CPUs after suspend/resume.
  • Improved support of ATI mach64.
  • Enhanced sensor monitoring on Intel Quartz Canyon and Ghost Canyon NUC.
  • Added reporting of TDP setting for AMD Ryzen APUs.
  • Enhanced sensor monitoring on ASUS WS C422 series.
  • Enhanced sensor monitoring on ASUS STRIX TRX40-E GAMING and PRIME TRX40-PRO.
  • Added reporting of Collaborative Processor Performance Control (CPPC) core order.
  • Enhanced support of AMD 3rd Gen Ryzen Threadripper.
Can you note where this is located? I have been searching and have not found it yet. 3900x here.
In the main window under the CPU node. If you're using the Sensors-only mode, you will need to deactivate it for the main window to show up.
Rapidian
Thank you. And as others have said, keep up the good work on this great tool. More power to you. I wish I could contribute to it.
