Hi, I've been using HWiNFO for years, thanks for this great software.
After every update I just load my settings from the .reg file. Sometimes a lot of sensors disappear, or they are not even sensors, the software might just be creating the blank lines, so I hide them, let's say, 20, 30 of them. Sometimes they come back so I hide again. Not a big issue, just reporting.
Sometimes after loading the .reg, rebooting the pc the sensors that I moved around show up the in original fields, so I move them again, save the .reg file, and once loading it sometimes it goes ok, sometimes it does not.
About sensor reading,
VDDP is reporting 0.928, bios is set to 0.900, RM reads 0.900. - Just saying, I trust more HWiNFO than RM.
VDDG is not showing up in HWiNFO - I've checked a thread saying to disable it in the main summary in order to show at sensors. It says is under cpu node but seems I can't find this.
DRAM voltage is set to 1.465 in bios and HWiNFO shows 1.496.
VDDCR_SOC voltage is set to 1.05 in bios, HWiNFO shows 1.05 for SoC Voltage (SVI2 TFN) and 1.064 for VDDCR_SOC.
Before Zen2, while using Zen1, what used to show me correct value for vcore was CPU Core Voltage (SVI2 TFN), always matching with CPUz reading. But now on Zen2 it changed to Vcore, and CPU Core Voltage (SVI2 TFN) has always a higher voltage value, usually a positive offset of more or less 0.041V under load. - EDIT: just learnt TFN sensors are just what is being read at the VRMs, influenced by the LLC.
I'm on a Asrock x370 mobo.
