HWiNFO v7.22 released
HWiNFO v7.22 available.
Changes:
  • Improved support of AMD Ryzen 6000 series.
  • Added monitoring of next-generation AMD chipset temperature.
  • Added option to disable validation of window positions.
  • Enhanced sensor monitoring on Intel NUC12 series.
  • Added NVIDIA GH100, GH202, AD102, AD103, AD104, AD106, AD107, GB100, GB102.
  • Added reporting of ASIC Quality for AMD Vega and Navi discrete GPUs.
  • Added fan speed monitoring on ASUS FA506 series.
  • Improved support of next-generation AMD CPUs/APUs and GPUs.
  • Added monitoring of video decoder and encoder usage on AMD Navi GPUs.
  • Fixed monitoring of some EVGA EC sensors.
  • Fixed Intel Arc graphics badge.
  • Added option to disable snapping of sensor windows.
  • Added NVIDIA GeForce RTX 3090 Ti.
  • Fixed MHTML report.
  • Updated HTML and MHTML reports to use UTF-8 encoding.
  • Added reporting of ASIC Manufacturer for NVIDIA GPUs.
  • Updated several languages.
Build 4731 was released to replace v7.22 release to fix a bug causing the sensor ToolTips setting not to be applied.
Seems to be a problem of caching when the previous files remained in cache.
I have now purged all server caches so please try to download again.
If it still won't work try to purge your browser's cache or download from FossHub.
Then it must be your browser caching the old file. Try to empty its cache or download from FossHub.
f14tomcat
Thank you for fixing it. I did absolutely nothing and just DL'd it again using exactly the same browser (FF) and method. I cleared nothing. I used Local. Now it updates to 4731. DL file size changed from 9939kb to 9937kb. Amazing. ;)
Where and how can I see this ASIC report? I have Zotac Geforce RTX 3050 Twin Edge OC.
In the main window with a tree on left side under Video Adapter. If you're using Sensors-only mode you'll need to deactivate it first for that window to show up.
