HWiNFO v7.43-5080 Beta released
HWiNFO v7.43-5080 Beta available.
Changes:
  • Enhanced sensor monitoring on ASRock A620 series.
  • Added NVIDIA GeForce RTX 4070.
  • Improved monitoring of Corsair Commander CORE, CORE XT, ST.
  • Enhanced temperature monitoring of AMD X670/B650 chipsets.
  • Added monitoring of GPU available memory for NVIDIA and Intel GPUs.
  • Fixed support of Renesas RAA229132 PWM.
  • Enhanced support and monitoring of AMD Van Gogh.
  • Added fan speed monitoring of Valve Steam Deck.
  • Added separate monitoring of static and dynamic PL1/PL2 values.
  • Added DIMM SPD information and temperature monitoring for Intel Sapphire Rapids, Emerald Rapids, Granite Rapids and Sierra Forest.
At some point recently Corsair was added to the monitoring. I have the H150i Elite Capellix with the odd, integrated Commander Core. I would like to say thank you. The 3 fans, pump, water and the extra sensor I use for intake air temp all read consistent with iCue. It is so nice to have that info together with the rest of my fan and temp numbers.
Thank You
Yes! Thanks for adding support to Corsair hardware. I'm so happy!
Edit: Just bought the Pro to show support. =)
