HWiNFO v8.29-5775 Beta released
SDUGoten
Win7 SP1 x64 - I do not confirm - Process Hacker, Services tab:
Hwinfo_206, Hwinfo Kernel Driver (V206), Driver, Running, System Start, Normal, C:\Windows\System32\Drivers\Hwinfo_x64_W7_206.Sys, \??\C:\Windows\System32\Drivers\Hwinfo_x64_W7_206.Sys
Most likely, the launch of the driver is blocked by an antivirus or via a virtual machine.
Looks like some other process is blocking access to the driver. Try to reboot the system.
1st reboot, same error. 2nd reboot, it resolve the problem. I have no clue what is causing it. This is not the first time I encounter this error when my computer freeze. I don't expreience this problem before this version. My computer always freeze due to Nvidia unstable drivers on 5000 series, but never had this issue before this version.
Are you maybe using some other monitoring/tweaking/fan or RGB control software?
I am using Fan Control and Open RGB. However, it's been fine without issue for the last 2 months tho.....
Wonder if anything has been changed regarding the process of injecting the driver on standalone version?
