HWiNFO32 and HWiNFO64 v3.91-1490 Beta released
HWiNFO32 v3.91-1490 Beta and HWiNFO64 v3.91-1490 Beta available.
Changes:
  • Added recognition of Intel Knights Corner.
  • Added support of SMSC SCH5327 sensor monitoring.
  • General sensor monitoring improvement (performance, reliability).
  • Added preserving of graph positions.
  • Improved IPMI support.
  • Added reporting of Firmware Version Information (BIOS, OROM, Reference Code) under SMBIOS/DMI if supported by BIOS.
  • Enhanced support of AMD Southern Islands and London series (clock, config, sensors).
They point correctly. Maybe your browser has the old page cached, please try to refresh (F5 or Ctrl-F5).
mididoc
Changes:
i saw, you list now the intel xtu extreme tuning bios settings.
this is fine.
this should be on the summary page beside the JEDEC settings.
very important to see, which settings the bios uses.
thanks
:cool:
Intel XTU settings have been there since a longer while. Or do you mean the Firmware versions?
This might be important, but unfortunately they are not always providing correct information (there might be a BIOS bug on some machines).
mididoc
well i don't verify all settings all the time.
just scrolled through and saw it.
these settings i wanted long time.
:cool:
