HWiNFO32 and HWiNFO64 v4.17-1918 Beta released
HWiNFO32 v4.17-1918 Beta and HWiNFO64 v4.17-1918 Beta available.
Changes:
  • Fixed reporting of GPU Power/Current on certain CHL controllers.
  • Added support of CHL8203, CHL8212 and CHL8213 on GPU.
  • Added preliminary support ITE IT8732.
  • Separated reporting of GPU codename.
  • Improved Intel Haswell support.
  • Improved AMD Kabini support.
  • Added AMD Radeon HD 7990 (Malta).
  • Added reporting of GPU Serial Number for later ATI/AMD GPUs.
  • Enhanced sensor monitoring on Apple machines.
  • Added AMD Radeon HD 7730.
  • Added support of NCT6683D hardware monitor.
  • Avoid polling of nVidia GPUs disabled by Optimus.
  • Added monitoring of some ACPI values.
Done and Done.
I like the work you have done on GPU as it applies to my AMD ATI 6870 (Asus) Card. Intel SandyBridge resident GPU on the MB looks good to. :D
Martin I have been meaning to ask you this ..... At the bottom for the Sensor Status Screen, there is numbers counting up. What are they telling me and what are they for? :huh:
Best Regards, :cool:
Crysta
Thanks for the feedback Crysta.
If you mean the timer below the "Reset Values" button, it's a timer which shows you for how long are the sensor values sampled. If you reset the values, it gets reset too. So for example if somebody cares about the average values, this information might be useful.
:P OH OKAY. When I first saw I though it might be GMT/UTC for screen shots but that didn't work neither. I have never found the need to rest. O.o :D
