I have had this installed for about a day, through several Logons. I have gone through the various machinations to endeavor to get the Task newly updated and did check to see that it got autodeleted and rewritten. Martin, I have been all over that Task and I can not find any delay in it, of several seconds, as you suggested you were going to setup, that you mentioned in another post that we were conversing in. I am guessing that, that wasn't possible.
This is from Task Scheduler Status "The task is currently running. (0x41301)" for HWiNFO64 in W 8.0 Pro. All of the other tasks are "0x0" when they are running. Frankly Martin, I am not seeing any difference in startup. The best way I have found, is simply to delay login on W 8.x, after power up. On W 7, that had various successes in general, mostly because W 7 has startup issues going back as far as NT. The new startup system in W 8, seems to have solved all the problems I had experienced in W 7, for years.
Otherwise, as far as I can tell everything else is running well on my rig, with HWiNFO64.
If you need more let me know, Martin,
Best Regards,
Crysta
