HWiNFO32 and HWiNFO64 v4.25-2005 Beta released
HWiNFO32/64 v4.25-2005 Beta available.
Changes:
  • Added support of RTSS 5.3.2+ for OSD with up-to 4096 characters.
  • Added reporting of drive warning status based on SMART.
  • Added drive health status icon (OK/Warning/Failure) to summary window.
The "drive health status icon (OK/Warning/Failure) to summary window" looks good.
As I have shown you, I have the Sensor window crunched down and positioned on the right side of my monitor. Would it be possible to add a "Tool Tip" that would expand the Description Column when the cursor hovers on a line?
Best Regards,
Crysta
A "Tool Tip" for the sensors window/sensor entry you mean ?
No .... Its the Sensor Status Display Window. The line by line descriptions are abbreviated and it would be helpful if they would expand when I hover the cursor over them, No Entry Required. I missed the word "Status" before .... O.o :D
Sorry, but I don't understand which window and entry you mean :huh:
Maybe a screenshot would explain it better ;)
Seek, and you shall receive .... :D
This is my Desktop. Usually "System Explorer" is more transparent. The issue I am referring to is in the "Sensor" column.
Hope this helps Martin.......
:D Picture is worth a 1000 words. Just fine tuning as far as you have gotten on the reformat.
Thank You for giving it a think.... :cool:
Crysta
