HWiNFO32 and HWiNFO64 v4.47-2333 Beta released
HWiNFO32/64 v4.47-2333 Beta available.
Changes:
  • Improved sensor indexing. For some addons (i.e. HWiNFOMonitor, Rainmeter) it will be required to reconfigure existing settings.
  • Fixed changing of sensor items order via the layout tab.
I like to see ctdp currently set for the cpu, could you implement this in HWiNFO. It would be great... :blush:
cTDP can be found in the main HWiNFO window (with tree on the left side). If you're using sensors-only mode, you will need to disable it in order to get that main window.
what i mean configurable TDP, in which tree list?
I mean the same. In the main window under the CPU node.
hmm... i saw CPU Thermal Design Power only no cTDP and it set to 65.2W. I currently set cTDP to 45 on BIOS.
Please attach a HWiNFO Report File and Debug File so I can check why it doesn't report it.
A long time...... :)
I just wanted to let you know that all your chnanges to the formating of the Sensor window (drag 'n drop etc) are now working for me once again. :D Thank You for your dilegence as well to the other users who were able to put into words what the problems were. All I could have told you was I am getting a mess with out doing anything other then loading the next version. I ended up just "fixing the order" and resting the order and leaving it alone. Now it is working for me once again and better then ever. :D
Best Regards,
Crysta
