HWiNFO32 and HWiNFO64 v5.07-2680 Beta released
HWiNFO32/64 v5.07-2680 Beta available.
Changes:
  • Enhanced support of Intel Knights Landing.
  • Enhanced support of Intel Kaby Lake and Denverton.
  • Added workaround for some Intel RSTe drivers causing crash.
  • Added new sensor to monitor current memory timings.
  • Restored lost Windows 98 compatibility.
  • Added monitoring of Thermaltake DPS PSUs.
  • Added monitoring of Enermax Digifanless PSUs.
  • Added monitoring of Corsair RMi and HXi series PSUs.
  • Enhanced sensor monitoring on ASUS H110 series.
  • Enhanced reporting of ATA features (security, version).
  • Fixed SMART reporting on Samsung NVMe drives (requires latest 950 Pro driver).
  • Added option to show average values in tray and to divide values by 1000.
  • Added ability to specify a custom period (last N samples) for calculating average sensor values.
  • Fixed monitoring of AMD Carrizo and Nolan CPU sensors.
  • Added monitoring of HID-capable UPS devices.
PhotM
Thank You for the new UPS Info. There is a description missing by a %. I don't know what the % means?
Best Regards,
Crysta
PhotM
Thought you might like this:
Source
HWiNFO64
Summary
Stopped working
Date
‎2015-‎11-‎13 14:17
Status
Report sent
Description
Faulting Application Path: C:\Program Files\HWiNFO64\Current Beta\HWiNFO64.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: HWiNFO64.exe
Application Version: 5.0.7.0
Application Timestamp: 56444c07
Fault Module Name: HWiNFO64.exe
Fault Module Version: 5.0.7.0
Fault Module Timestamp: 56444c07
Exception Code: c0000005
Exception Offset: 0000000000187902
OS Version: 10.0.10586.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 6343
Additional Information 2: 63435ec168c70e60163d0d4675f5ea13
Additional Information 3: d16c
Additional Information 4: d16c5e3c940954bbf0ac689f3891c9ac
Extra information about the problem
Bucket ID: 800c5891ebf554155625e3ca33da2b06 (120355645512)
Log Name:      Application
Source:        Application Error
Date:          2015-11-13 14:17:18
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      TammyLacey
Description:
Faulting application name: HWiNFO64.exe, version: 5.0.7.0, time stamp: 0x56444c07
Faulting module name: HWiNFO64.exe, version: 5.0.7.0, time stamp: 0x56444c07
Exception code: 0xc0000005
Fault offset: 0x0000000000187e90
Faulting process id: 0x8b8
Faulting application start time: 0x01d11e58a912e056
Faulting application path: C:\Program Files\HWiNFO64\Current Beta\HWiNFO64.exe
Faulting module path: C:\Program Files\HWiNFO64\Current Beta\HWiNFO64.exe
Report Id: 7d04b234-415b-44a6-b6cb-ebdc33f8a8f1
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2015-11-13T21:17:18.157790600Z" />
    <EventRecordID>554</EventRecordID>
    <Channel>Application</Channel>
    <Computer>TammyLacey</Computer>
    <Security />
  </System>
  <EventData>
    <Data>HWiNFO64.exe</Data>
    <Data>5.0.7.0</Data>
    <Data>56444c07</Data>
    <Data>c0000005</Data>
    <Data>0000000000187e90</Data>
    <Data>8b8</Data>
    <Data>01d11e58a912e056</Data>
    <Data>C:\Program Files\HWiNFO64\Current Beta\HWiNFO64.exe</Data>
    <Data>7d04b234-415b-44a6-b6cb-ebdc33f8a8f1</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
Source
HWiNFO64
Summary
Stopped working
Date
‎2015-‎11-‎13 14:17
Status
Report sent
Description
Problem signature
Exception Offset: 0000000000187e90
Locale ID: 1033
Additional Information 1: 2ab2
Additional Information 2: 2ab207f024e4c154c9c6e770e2c0b897
Additional Information 3: aaf2
Additional Information 4: aaf2a8cf5c17e0b3942e1dce5ad6c839
Bucket ID: 0150c9cc21989aaf05fd3143e049073a (120355645492)
I don't remember HWiNFO crashing before at anytime. This was at startup in W 10.0 Pro 1511 Build 10586.3 Release 2015.11.10
Best Regards,
Crysta
Can you please try to capture that crash with Debug Mode enabled and then submit the DBG file produced ?
wawans1975
as you can see with image file i attached,
with win10 (still build 10240) seems expanding sensors across multiple tables not working anymore   and i have to manually cut and paste sensors  to make it
and i found logging button has button and text that offside / cutoff from itself (text buttons checked in hwinfo64 sensor settings), may be you can resize the button or remove the icon.
The issue you see with expanding sensors is because you have "Fixed order" disabled. Only if that option is enabled, sensor items are automatically placed in new lists. If you use custom sensor order, then HWiNFO won't change their order (place them into new lists).
The problem with logging button is a bug and I'll fix that.
PhotM
I presented those errors the way I did Martin, because it hasn't happened before or after, so no possibility of Debug File.
Martin, essentially the way I am seeing this is, an accumulation of intermittent issues that have started cropping up for me, on and since Build 10576. The other ones still occur intermittently, it will take a while to track them down......   :dodgy:  and sort them out if they don't get sorted out themselves or by MS.
So I will keep submitting these as they come up and just put them in your file. I will try to remember to tell you when I stop seeing specific issues or you can ask me.
Crysta
VictorVG
Martin!
Big thanks on this version. Rescued in the control of iron and the network after updating the network equipment and the HDD on the machines (combine business with pleasure - to change the router TP-LINK R460 which was not enough memory to run at speeds of 20 Mb/s why constantly had to restart it and updated the entire cable laying with 100-BASE-TX on the 1000-BASE-T and the HDD on the server the benefit of consumer goods are more reliable and the CPU on one of the machines was replaced with a Pentium DC E5800 on the Core 2 Duo E8500 :) . So far he has not revealed deficiencies.
P.S.
TP-LINK is no technical documentation produced by the equipment is not offered - only general descriptions and leaflets. Well, but with a 3COM/D-LINK/ZyXEL no such problems - their equipment can find the documentation, so that it and fix it, and you can customize. :)
