HWiNFO32 and HWiNFO64 v5.25-2865 Beta released
HWiNFO32/64 v5.25-2865 Beta available.
Changes:
  • Enhanced AMD Polaris support.
  • Changed MVDDC to VDDCI on AMD Bonaire, Hawaii, Tonga.
  • Added support of SMSC SCH5627 and SCH5636 HW monitors.
  • Added NVIDIA GeForce GTX 1080.
  • Added support of AquaStream Ultimate.
  • Removed showing of average values for some sensors where this has no meaning.
  • Added experimental reporting of CPU current/power for some later ASUS mainboards.
  • Added reporting of ASIC Quality for AMD RV7xx/M9x and later GPUs.
  • Added reporting of ASIC Quality for NVIDIA Fermi, Kepler and Maxwell GPUs.
ssateneth
"Added experimental reporting of CPU current/power for some later ASUS mainboards." Does this include ASUS RAMPAGE V EXTREME? Whats changed?
edit: I see new CPU current and CPU power under the ASUS EC sensor chip. The CPU Power seems to take existing VCCIN sensor under the Nucoton NCT6791D chip and multiply by the new CPU Current sensor. How reliable do you believe this new sensor is?
Yes, that sensor includes ASUS RAMPAGE V EXTREME.
That's right - the current is measured on the VCCIN rail for Haswell systems and thus multiplied by the respective voltage. I'm not sure how accurate it is, as it's an ASUS-proprietary solution that's not described to public. But the advantage of this is, that it works also when SVID is disabled (which causes the internal CPU power measurement logic not to work).
