HWiNFO32 and HWiNFO64 v5.47-3115 Beta released
HWiNFO32/64 v5.47-3115 Beta available.
Changes:
  • Added NVIDIA GeForce GTX 1080 Ti.
  • Fixed reporting of AMD Ryzen memory timings if first memory controller is not active.
  • Fixed occasional erratic sensor readouts on ASUS CROSSHAIR VI HERO.
  • Added reporting of SMU Firmware Revision for AMD Ryzen.
  • Simplified adjusting of sensor item settings via right-click context menu.
  • Added board-level monitoring of CPU current and power on ASUS CROSSHAIR VI and PRIME X370.
  • Enhanced sensor monitoring on GIGABYTE X370 series mainboards.
wawans1975
seems on am4 platform, hwinfo64 still reading sensors that not relevant on my video cards (see at screenshot in zip file).
i have attached zip file containing .dbg and .csv file for you to check.
  • New Compressed (zipped) Folder.zip
If you mean values like HBM, PLX temperature, etc. then this was a bug in some earlier versions of Crimson drivers. You will need to upgrade to a later version.
BTW, are all the GIGABYTE (ITE) sensor values correct (in sync with the GIGABYTE system viewer tool) ? Would be great if you could post a side-by-side screenshot of HWiNFO and the GIGABYTE tool showing all those sensor values.
wawans1975
Hmm, i must put back those cards to my fm2+ mainboard first to make sure, i think those values already eliminated by HWiNFO with this 16.12.1 version crimson driver and that mainboard.
Edit: I remember now, I hid those values. Anyway, thank you very much for this great app of yours.
I think they synced already, but may be i missed.. you could check it again
