HWINFO64 Crashing when loading sensors
AshDarko
Its been working fine for a long time but after latest update I have noticed some instability after loading sensors, the programs just closes. No error message or other pop up.
See attached DBG report. Any ideas?
Which version are you running? Try the latest Beta version v7.05.
If that won't help you might need to do a Reset Preferences in HWiNFO main settings.
AshDarko
I'm running version 7.04-4480.
I will certainly try "Reseting Preferences" Will this reset all the onscreen info when i run riva tuner etc?
Yes, it will reset all those settings. So first I'd recommend to try v7.05 Beta, that has some fixes for issues you're experiencing and might not require resetting preferences.
