HWinfo64 doesn't start
shaav
My HWinfo64 (version 5.73.3345) isn't working anymore. Does anybody know why? I have attached a debug file and hope it helps to solve he problem. I'm a huge fan of this software!
What happens when you start it, does it crash ?
Try to do a "Reset Preferences" via Settings before starting the scan if that helps.
shaav
"Try to do a "Reset Preferences" via Settings before starting the scan if that helps. "
- I just deleted the configuration file. I guess thats also a way to go.
"What happens when you start it, does it crash"
- If I start the software by not doing a mark at "sensors only" the program starts as usual. Then, when I click on the "Sensors" button, the program crashes: "HWiNFO64 isn't working anymore".
- If I enable "Sensors-only" while starting the program, it starts to detect sensors and aborts before finishing. The program closes without any hint why that happened.
EDIT:
I found the "Reset Preferences" button in the settings. HWiNFO64 is now working again. THANKS!
FYI - deleting the configuration file (INI) is not same as doing "Reset Preferences", which erases user-/machine-specific settings stored in the registry
