HWInfo64 not reading DIMM Temperature
rares495
Hello.
I'm running 2x8GB G.Skill Trident Z F4-3600C15D-16GTZ memory on an MSI X470 Gaming Pro motherboard. HWInfo64 is not reading the temperature sensors of my DIMMs. I've seen people with this exact memory post screenshots which show temperature readings so I'm pretty sure that my memory comes with temperature sensors.
I've attached the report & debug files. Please take a look and let me know what's going on.
Thank you.
  • r1.HTM
Please attach a Debug File with sensor data - you need to open the sensors window before closing HWiNFO and grabbing the DBG file.
I'm sorry, but I don't recognize a valid DIMM thermal sensor there. Is there any other tool (AIDA64 or SIV) reporting the DIMM temperatures?
rares495
Attached image from SIV.
I guess there is no sensor after all. :(
Sorry to have wasted your time.
rares495
I did some online digging and found two screenshots of Thaiphoon Burner reading the same memory kit as mine. They do show a thermal sensor(third column).
Meanwhile, on my own kit there are only two columns. No thermal sensor. How is that possible? Even the PCB revision is the same.
Sorry, I don't know why the difference. The only thing I see is that there's really no thermal sensor appearing on your modules.
